Unity 4.21 and the sa web page
Tommer Catlin Fri, 01/18/2008 - 08:24
You might need to "kick" unity. Restart IIS or actually restart the server. But first, try use the SA page on a different computer or from the console directly. This will help you eliminate if it was the actual server or the workstation you are on.
eschulz Fri, 01/18/2008 - 08:44
I've seen this behavior when the password for the Unity mesg store account was changed. The settings for the Unity COM+ app may be out of sync. You can try updating the logon credentials for this with the following...
- Open Component Services from the Windows Administrative Tools
- Drill down into Component Services / Computers / My Computer / COM+ Applications / Cisco Unity
- Right click Cisco Unity and select Properties
- In the Properties window you should be able to update the password in the Identity tab
Eric
