2821 IOS IP Base upgrade to Adv IP Serv
Jan 18th, 2008
  • Cisco Employee,
Is there any posibility to do this upgrade on a router 2821 from IOS IP Base feature set upgrade to ADV IP Services?
I would appreciate any help!
Overall Rating: 4 (1 ratings)
Danilo Dy Fri, 01/18/2008 - 08:23
  • Blue, 1500 points or more
Sure, you need minimum 256MB DRAM and 64MB FLASH which comes as default. Also, you need to purchase the ADV IP SERVICES as it is a feature upgrade
Dandy
