Rajesh Revuru Fri, 01/18/2008 - 10:25
You can setup a SMTP notification in your unity connection so that it will notify via an email if you have any new voicemail. Following is the reading
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/administration/guide/2xcucsag200.html
There is also licensed add-on for unity connection called as unity inbox and pca, which will allow to send an email with a link to unity connection host where you can listen to the messages. You can also integrate with your IMAP clients.
richb1971 Fri, 01/18/2008 - 10:54
Thanks for reply. How does the IMAP work? Are there any docs to follow?
