DFM custom interface settings
Jan 18th, 2008
I have an edge internet router, and would like to change the %utalization threshold for just that device.
I've added the interface to custom interface 1 (I think), and changed the threshold settings on it (and applied it).
The interface is still alerting at the previous value. (fixed)
Is there a way I can find out which interfaces are matching the rule I created for the custom interface? The interface is now apart of the group, however is there a way to find out if I accidentally got other interfaces in the filter?
Joe Clarke Fri, 01/18/2008 - 10:26
You need to float your custom group up to the top under DFM > Configuration > Polling and Thresholds > Setting Priorities, then save, then re-apply settings.
You can always view membership by going to DFM > Configuration > Polling and Thresholds > Managing Thresholds > (Select Group) > View > (Click on the View ... link).
martinUpchu Fri, 01/18/2008 - 10:50
I've noticed that sometimes (most of the time) when I try to pull up this screen, DFM is not pulling the information from custom groups. I did set the custom threshold earlier (yesterday), but today I can't get to it.
Running LMS 2.6
Joe Clarke Fri, 01/18/2008 - 10:55
The customizable groups will be seen under User Defined Groups, and not under DFM.
Joe Clarke Fri, 01/18/2008 - 11:13
Which customizable group did you modify? I did a quick test with a Customizable Interface Group, and it should up just fine. You should also go back, and make sure your customized settings are still in place.
martinUpchu Fri, 01/18/2008 - 15:06
I found the problem was my user account. For some reason my user account was locked out. I logged in with the administrator account, I even created a new account with the same permissions as my user account, and both were able to see the custom group.
martinUpchu Fri, 01/18/2008 - 15:07
