Voice mail port dont answer
Jan 18th, 2008
Event Type: Error
Event Source: CiscoUnity_TSP
Event Category: None
Event ID: 118
Date: 12/23/2007
Time: 7:33:45 AM
User: N/A
Computer: RSTTX1-UNITYP1
Description:
Cisco Unity-CM TSP: Device 53 (Cisco Unity port 49) was unable to connect to the Cisco CallManager cluster.
Examine the cluster connection settings and verify that they are correct. The device will keep trying to connect in case the Cisco CallManager cluster is temporarily unavailable.
The Cisco Unity-CM TSP version is 8.1(2).
Cisco Unity 4.2 Build 4.2(1)
Please also see the attachment of the logs
Ginger Dillon Tue, 01/22/2008 - 08:15
Hi -
I checked out your application event log and saw many of these error events - 822. This is an event I know well. Check the security event log just before the 822 errors started occurring. Someone connected to the Unity server in terminal services "Console only mode". This is not a supported way to access the Unity server and will result in these errors, which require a server reboot to correct. Using Remote Desktop Connection is a supported mode of accessing the Unity server, just not in console-only mode.
Hope this helps, Ginger
