Cisco 871W
Jan 18th, 2008
Router defaults after I unplug the power?
Brandon Buffin Fri, 01/18/2008 - 11:44
Are you saying your router goes back to defaults after losing power. If so, are you writing the configuration to memory after making changes? After making config changes, issue the "wr mem" command.
Hope this helps.
Brandon Buffin Fri, 01/18/2008 - 12:31
Can you telnet or console to the router and issue the "wr mem" command after making a config change and see if that helps?
