01-18-2008 11:05 AM - edited 03-03-2019 08:19 PM
I have a Cisco 821 router with 1 WAn and four Switch ports. I want to terminate another WAN connection on to the same route what steps should i take
01-18-2008 11:50 AM
Hi, if you load an 'advanced ip services" image on it, you can assign one switch port to a separate vlan, and terminate the new connections there.
01-28-2008 01:16 PM
Can i connect another WAN connection on that port and since i m doint nat so what will be the impact
01-28-2008 01:17 PM
Yes you can and as long the router is configured correctly everything will work nicely.
