Port Forwarding issue 871 ethernet router
Jan 18th, 2008
I cannot connect to my dvr from outside my network. The port is open and working inside my LAN. I used the following commands to no avail. Any ideas? I've tried just about everything
ip nat inside source static tcp 192.168.1.10 7000 interface FastEthernet4 7000
access-list 100 permit tcp any any established
access-list 100 permit tcp any any eq 7000
Brandon Buffin Fri, 01/18/2008 - 12:29
  • Purple, 4500 points or more
Try the following:
ip nat inside source static tcp 192.168.1.10 7000 1.1.1.1 7000 route-map nonat extendable
access-list 140 deny ip host 192.168.10.1 any
access-list 140 deny ip any host 192.168.10.1
access-list 140 permit ip any any
route-map nonat permit 40
match ip address 140
Hope this helps. If so, please rate the post.
Brandon
marc_eli4 Fri, 01/18/2008 - 14:07
Thanks for the reply.
That did not solve the issue.
I can get to the DVR username/password prompt but when I put in the password, the prompt just comes right back until I try it three times and it logs out. Is there a way I can tell if I am actually connecting to the dvr from the outside.
plumbis000 Tue, 01/22/2008 - 13:14
Well, if you are getting a username/pass prompt it sounds like you are making a connection. If you wanted to verify, during a connection, login to the router and issue "show ip nat trans" to see your active NAT translations and check to see if there is a translation.
