ASA5505 "outside_access_in" blocking UDP
Answered Question
Jan 18th, 2008
Greetings all! This is sort of elementary for everyone (and may be silly, once you hear what I'm doing...) but I'm stumped.
Here's what I've got:
- ASA5505
- Xbox LIVE service: 88 UDP & 3074 TCP-UDP
I've searched around these forums and found help, but they were geared more towards the PIX 501. Anyways, here's what I've done:
- setup my xbox to a static IP (192.168.1.200)
- entered a service group with the above mentioned ports for both UDP and TCP
- created 3 NAT rules for those ports to go straight to the Xbox.
- added the xbox to a ACL so that those ports come into the Xbox
What I get, when testing, is this:
4 Jan 18 2008 20:01:18 106023 65.59.234.162 72.12.119.218 Deny udp src outside:65.59.234.162/55619 dst inside:72.12.119.218/3074 by access-group "outside_access_in" [0x0, 0x0]
In the "outside_access_in" group, I have:
1 True any Xbox360 Xbox_LIVE Permit Default
I'm not sure why, but the packets, when coming back inside, are being denied. I'm using ASDM to set this up and I know a lot of you like the command line. If any of you can offer any help, I can run a command using command line and give you any outputs.
Thanks for any help my friends.
CH
Correct Answer by acomiskey about 9 years 2 days ago
Do you have the source ip's of xbox live?
Sorry, the Xbox_LIVE object group needs to be the destination port.
access-list outside_access_in extended permit udp any interface outside eq 88
access-list outside_access_in extended permit udp any interface outside eq 3074
access-list outside_access_in extended permit tcp any interface outside eq 3074
Overall Rating: 5 (1 ratings)
acomiskey Fri, 01/18/2008 - 18:22
post a...
show run nat
show run access-list outside_access_in
interknox Fri, 01/18/2008 - 18:40
show run nat:
"nat (inside) 1 0.0.0.0 0.0.0.0"
show run access-list outside_access_in:
"access-list outside_access_in extended permit object-group Xbox_LIVE any host Xbox360"
Thanks!
acomiskey Sat, 01/19/2008 - 05:55
Sorry I meant show run static. Why don't you just post a sanitized/cleaned config.
show run
interknox Sat, 01/19/2008 - 06:21
show run static:
static (inside,outside) tcp interface 3074 Xbox360 3074 netmask 255.255.255.255
static (inside,outside) udp interface 3074 Xbox360 3074 netmask 255.255.255.255
static (inside,outside) udp interface 88 Xbox360 88 netmask 255.255.255.255 dns
show run:
: Saved
ASA Version 8.0(3)
hostname greylock
domain-name ch.local
enable password RONX1BXdqaFcKwP9 encrypted
names
name 192.168.1.200 Xbox360
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.169 255.255.255.0
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group DSL
ip address pppoe setroute
passwd 2KFQnbNIdI.2KYOU encrypted
boot system disk0:/newstuff/asa803.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 208.67.222.222
name-server 208.67.220.220
domain-name interknox.net
object-group service Xbox_LIVE
service-object udp source eq 88 eq 88
service-object tcp-udp source eq 3074 eq 3074
access-list inside_access_in extended permit ip host Xbox360 any
access-list inside_access_in extended permit ip any any
pager lines 24
logging enable
logging asdm warnings
logging from-address [email protected]
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp deny any outside
asdm image disk0:/newstuff/asdm-603.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 68.152.211.86 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 0.0.0.0 0.0.0.0 outside
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
vpdn group DSL request dialout pppoe
vpdn group DSL localname my dsl email
vpdn group DSL ppp authentication pap
vpdn username my email password *********
dhcpd auto_config outside
dhcpd address 192.168.1.125-192.168.1.150 inside
dhcpd dns 208.67.222.222 208.67.220.220 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
ntp server 131.107.13.100 source outside
ntp server 129.6.15.29 source outside
ntp server 129.6.15.28 source outside prefer
username chris password TYGBt4.L24KH1.mU encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:1d79690fe1b4b7246c3a87153b23040b
: end
NOTE: I cut out some of the "interfaces" because of message length restrictions on the forums. Other interfaces aren't in use, FYI.
Thanks again.
acomiskey Sat, 01/19/2008 - 06:42
Your access list is not correct.
should be...
access-list outside_access_in extended permit object-group Xbox_LIVE any interface outside
or
interknox Sat, 01/19/2008 - 06:57
Okay, using ASDM, it went from this:
to...
access-list outside_access_in extended permit object-group Xbox_LIVE any any
and it still blocks UDP ports (from log):
4 Jan 19 2008 09:48:27 106023 65.59.234.162 72.12.119.28 Deny udp src outside:65.59.234.162/43971 dst inside:72.12.119.28/3074 by access-group "outside_access_in" [0x0, 0x0]
Correct Answer
acomiskey Sat, 01/19/2008 - 07:07
interknox Sat, 01/19/2008 - 07:52
Okay, it's working now and I found that there were 2 problems. One problem ended up being that the Xbox_Live group's ports had the source/destination as the same thing, instead of "default" for the source. For instance, I had:
destination: udp 3074
source: udp 3074
When in fact, Xbox LIVE service doesn't use those ports at the source, so the ACL was blocking it. I changed it do:
source: default
Second, like you said, my outside_access_in group listed my destination as my Xbox360, when in fact that won't work, as that device is using a private IP, behind the firewall.
I changed both these things and it now works like a champ!!!
Thanks again for all your help. I'll be sure to rate/vote whatever for you anytime.
CH
