1760 - vic2-2BRI-/TE - vic-2FXO
Jan 19th, 2008
Router 1760 ccme 4.1
IOS c1700-adventerprisek9-mz.124-15.T1.bin
slot0 WIC-1ADSL-I-DG
slot1 empty
slot2 vic2-2BRI-/TE
slot3 vic-2FXO
Hello, I am facing the following problem:
When I plug-in the vic-2FXO card I am unable to see (and configute) voice ports 2/0 & 2/1
I will appreciate any help.
Overall Rating: 4.3 (4 ratings)
Paolo Bevilacqua Sat, 01/19/2008 - 03:12
  • Hall of Fame,
    Founding Member
Hi, send show diag. Most likely you do not have dsp resource and need to add the in the form of PVDM-256-XX modules.
pcameron Sat, 01/19/2008 - 03:12
  • Cisco Employee,
Do a SH DIAG and check the type of DSP module you have installed in the router. I suspect you don't have enough DSP resources for the 4 B channels on the 2 port BRI and the 2 port FXO ports.
Paste the SH DIAG output here so we can confirm.
thotsaphon Sat, 01/19/2008 - 03:57
  • Gold, 750 points or more
Hi all.
Seems you guys replied at the same time and made more sense to me as well.
Cheers ;-)
Thot.
pcameron Sat, 01/19/2008 - 04:16
  • Cisco Employee,
So now a race to give you the final answer :-)
You have a PVDM-256K-4= DSP module , which will only support 4 channels, which would be the 4 B channels of the BRI card, or the VIC-2FXO, but not both at the same time.
You will need a PVDM-256K-8= at the very least for this to work.
To understand DSP and hardware requirements , check out the DSP calculator on cisco.com -
http://www.cisco.com/pcgi-bin/Support/DSP/cisco_prodsel.pl
