dancampb Sat, 01/19/2008 - 06:26
  • Cisco Employee,
You will need to contact TAC.
Rob Huffman Sat, 01/19/2008 - 07:20
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi jianhua,
Dan is most correct here (5 points for your good work Dan!) I just thought that I would add this info for your TAC case. It may speed things up a bit.
CSCsd52483
Controller stuck at grub> prompt
Symptom:
A WLC2006, WLC2106 or NM-AIR-WLC6 may seen to display a "grub>" prompt on the console port. It will be unable to boot the
WLC software and will not be able to operate normally.
Workaround:
Replace the hardware.
Hope this helps! And best of luck.
Rob
taylor.robert Wed, 01/28/2009 - 04:24
Some very good new for everyone who has experienced this very frustrating error. I have found a resolution to this problem (well it fixed my issue, which certainly seems extremely similar to this one)...
Type what you see following the Grub command prompt...
Symptom:
A WLC526, WLC2006, WLC2106 or NM-AIR-WLC6 may seen to display a
Workaround:
For AIR-WLC526 / AIR-WLC2006 / AIR-WLC2106:
From the grub prompt use the following commands to boot primary image
grub> root (hd0,1)
grub> kernel /bzImage-primary root=/dev/ram ramdisk_size=32768 printk=yes
console=ttyS0,9600
grub> initrd (hd0,1)/initrd-primary
grub> boot
From the grub prompt use the following commands to boot secondary image
grub> root (hd0,1)
grub> kernel /bzImage-secondary root=/dev/ram ramdisk_size=32768 printk=yes console=ttyS0,9600
grub> initrd (hd0,1)/initrd-secondary
grub> boot
Then TFTP download an official version of WLC code, to install a bootloader
for the WLC.
This was the fix that I have been searching for - I hope it works for you too.
KR
Rob T.
amiresmailpour Wed, 04/01/2009 - 14:44
Hi guys,
I have the same problem, but the grub does not see (hd0, 1), it can only see (hd0), and when I enter there, and use the kernel command, then the grub gives this error message:
"Error 17: Cannot mount selected partition"
grub cannot do some of the commands, in the help items, there are many options, but in order to do that it needs to mount the kernel.
Any ideas is appreciated.
amir
Leo Laohoo Wed, 04/01/2009 - 16:24
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Hi Amir,
1. No spaces in the "(hd0, 1)";
2. If all else fails, raise a Cisco TAC.
amiresmailpour Thu, 04/02/2009 - 06:44
This is what I get:
grub> root (hd0,1)
Error 5: Partition table invalid or corrupt
Amir
Leo Laohoo Thu, 04/02/2009 - 14:43
  • Hall of Fame,
    2017 LAN, Wireless
Hi Amir,
Raise a Cisco TAC.
tdennehy Wed, 02/22/2012 - 09:55
I know someone who had this issue.  She took the cover off the controller and saw the compact flash module.  It wasn't seated properly, so she pulled it out and put it back in and closed the unit up.... and it booted.
Leo Laohoo Sun, 06/21/2009 - 18:23
  • Hall of Fame,
    2017 LAN, Wireless
Raise a Cisco TAC to get your appliance RMA-ed.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
