dbeare Sat, 01/19/2008 - 09:28
Wireless configuration is not one of the requirements of the 640-802. The main focus is on how it works and how different wireless security features work. As far as hardware, I would recommend at least 2-3 routers and switches, so you can set up some basic RIP, EIGRP and OSPF routing between routers, and so you can set up a simple VLAN. I used a 2521, 2610 and 2611 router and a 1900 and 2900 XL switches, but I would try to get some 2950's if possible. Best of luck!
