Multiple EAP Types on ACS 3.2
Answered Question
Jan 19th, 2008
I have the following problem:
- We have a WLC Version 4.2.61.0
-- We have a SSID wep-cloud
-- We have a SSID wpa-cloud
- We have an ACS Version 3.2
Now I would like to authenticate the SSID wep-cloud with LEAP on the ACS. At the same time, I would like to authenticate the SSID wpa-cloud with PEAP on the same ACS.
Is it somehow possible to use multiple eap types for one device (WLC) on the ACS.
If i configure the WLC under Network Configuration, I can set the Authenticate Using field "RADIUS (Cisco Aironet)" for LEAP or "RADIUS (Cisco IOS/PIX)" for PEAP.
Thanks in advance for your help.
Overall Rating: 4 (1 ratings)
