Unable to establish ISDN Conection
Jan 19th, 2008
When I given Command
Sh isdn status
allway fist layer deactivate and
second layer not activated.
I and many time tested line parameter
by isdn provider they tell me line parameter are ok. but when we connect line to nt1 and router they tell me isolation more then 1k arrive in line parameter.
whats probles tell me are who to solve.
paolo bevilacqua Sat, 01/19/2008 - 05:10
  • Hall of Fame,
    Founding Member
hi,
do "debug bri", "debug isdn q921" debug isdn q931" "term mon".
then isdn test call int x/y 1234
this will tell you what's going on.
Richard Burts Sat, 01/19/2008 - 18:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Paolo
Your suggestion of debugs is a good combination of debugs to investigate most ISDN problems. But if:
Sh isdn status allway fist layer deactivate and
then I am afraid that the results of the testing is going to be very predictable. What can 921 or 931 show if layer 1 and 2 are not active?
My suggestion is to look for a layer 1 issue:
- is the cable plugged into the correct port on the router?
- is that same cable plugged into the provider ISDN terminated connection?
- is that any possibility of a patch connection somewhere between the router and the NT1 that is not correctly connected?
- is the ISDN card the correct one to connect to an NT1?
Rick
paolo bevilacqua Sun, 01/20/2008 - 10:33
  • Hall of Fame,
    Founding Member
Hi Rick, with all debugs enable it's easy to see the proper sequence of events, and one doesn't have to ask repeatedly :)
