CCME Installation issue
manojpillai
HI
im trying to install a fresh CCME
but when im trying to extract both CCME and GUI files im getting this error.
CCME# archive tar /xtract tftp://192.168.13.26/cme-gui-4.1.0.1.tar flash:
%Error, "tftp://192.168.13.26/cme-gui-4.1.0.1.tar" is a directory.
i tried formatting flash and all things.
still im not able to install
please reply
Many Thanks
Manoj
paolo bevilacqua
yes, it is a know bug.
Try
ftp://:@ftp.cisco.com/cisco/voice/ip-phone/ip-iostsp/cme-gui-4.0.3.1.tar
If still problems, upgrade IOS image.
hope this helps, please rate post if it does!
rseiler
Level 3
Level 3
This is not a bug, you are using an invalid syntax:
Try 'archive tar /x tftp://192.168.13.26//cme-gui-4.1.0.1.tar flash:'
Note the double forward slash '//' after the ip.
This is clearly documented.
It's definately a bug - CSCek63178
Symptom:
When extracting a .tar file via the command line from a tftp or ftp server
the following error may occur:
Router#archive tar /xtract ftp://X.X.X.X/XXXX.tar flash:
%Error, "ftp://X.X.X.X/XXXX.tar" is a directory.
Conditions:
This problem is seen when executing the command:
archive tar /xtract
With the source file coming from an ftp or tftp server will result in an
error message indicating that the source file is a directory.
Workaround:
There is no known workaround.
Fix is in 12.4.13e, 12.4(11)XJ, 12.4.15T
