SSL VPN error
Jan 19th, 2008
I have a problem with SSL VPN client for webvpn.
I am using version client version 1.1.3 and until recently the ASA 5520 was working perfectly. However I am now getting the following error message after authentication
the ssl vpn http response code received from the gateway indicates an error, contact your network administrator.
Please could someone help resolve the problem or advice how I can troubleshoot the problem? Where can I see the error that the gateway indicates.
I have attached the relevant parts of the config:
amritpatek Thu, 01/24/2008 - 11:42
  • Silver, 250 points or more
Check the ip pool assigned to your ssl vpn clients. The error "The SSL VPN HTTP Response code received from the gateway indicates and error, contact your network administrator" usually appears because of DHCP problems. Following link may help you
http://www.cisco.com/en/US/customer/products/sw/secursw/ps2308/products_tech_note09186a00801b7615.shtml
