WAN connection for lab
Jan 19th, 2008
I'm setting up a NA/NP lab. I know that most people recommend connecting a DCE/DTE cable to serial ports to simulate the WAN connections, but I have access to ADTRAN CSU/DSU boxes that I could also simulate this with. Which is the better option to go with? I know I wouldn't have to set the clocking speed with my setup....
Edison Ortiz Sat, 01/19/2008 - 13:36
For Lab, Back-to-Back (DCE/DTE)is MUCH, MUCH easier. Personally, I haven't had the need to use real CSU/DSUs for WAN connection.
rsamuel708 Sat, 01/19/2008 - 18:04
Edison, I agree with you that I don't *need* to use the CSU boxes, it's just that I don't have the DCE/DTE cables, while I do have the CSUs and know how to set them up. I just wanted to know if I was missing out on anything else by configuring my network WANs this way.
Edison Ortiz Sat, 01/19/2008 - 21:40
If that's the case, then sure go ahead - you can use the external CSUs on this case :)
