Network Loop issues
The network consists of a 4507R Switch(Core) and 19 2960s as access switches.
Each on the Access swiches have vlan 1 and vlan x active on them. (where x is variable). Dhcp has been configured on the core for each vlan apart from vlan 1.
I noticed that each time a host is connected in any vlans i get a message in the core as follows:
src=10.1.2.155, dst=10.1.20.21, hl=20, tl=96, prot=17, sport=137, dport=137
in=Vlan1, nexthop=10.1.20.21, out=Vlan1
options=none
-Process= "IP Input", ipl= 0, pid= 82
-Traceback= 10A3B044 10A3B2E8 10A3CEFC 10A3DD04 10A3B854 10A3BBDC 10B96040 10B961C8 10B73C1C 10A57938 10A180F4 10A2DA14 10A2BBB8 10A2BD04 10A2BFC8 10623E5C
04:46:21: %IP-3-LOOPPAK: Looping packet detected and dropped -
src=10.1.2.155, dst=10.1.20.21, hl=20, tl=241, prot=17, sport=138, dport=138
options=none
04:47:21: %IP-3-LOOPPAK: Looping packet detected and dropped -
options=none
How do i resolve this. thanks
Overall Rating: 5 (1 ratings)
Edison Ortiz Sat, 01/19/2008 - 13:45
Traceback messages aren't good to be seen on any Cisco device. What version of IOS this 4507 is running ?
Here is an explanation of the message:
IP-3-LOOPPAK : Looping packet detected and dropped -\nsrc=[IP_address], dst=[IP_address],
hl=[int], tl=[int], prot=[int], sport=[int], dport=[int]
in=[chars], nexthop=[IP_address], out=[chars]\noptions=[chars]
Explanation A looping packet has been detected. A very common cause is a
misconfiguration of an IP helper address. The helper address should be the same address as
that of the server of the intended service. Putting the address of the router in the
helper address causes a routing loop to be created.
Recommended Action Analyze the source and destination address of the looped packets and
verify that the configuration of IP helper addresses in the router is correctly pointing
to the right device and is not pointing to the router itself. "
In short, you shouldn't configure ip helper-address on the switch, if the switch is the DHCP server itself.
HTH,
__
Edison.
