ASA 5505 - Cannot login via SSH
Answered Question
Jan 19th, 2008
As the title says, I cannot login via SSH. I've generated the certificates, etc., but when I connect to the terminal, my user/pass doesn't work.
Am I missing something? My user has full privileges on the box. Any help would be appreciated.
Thanks!
Correct Answer by pengfang about 9 years 1 month ago
Try/check this code
ssh 0.0.0.0 0.0.0.0 inside
aaa authentication ssh console LOCAL
username admin password admin privilege 15 (for example)
check your ssh client can support ssh v1 and v2
pls rate if it helps,
Overall Rating: 4 (1 ratings)
Correct Answer
pengfang Sat, 01/19/2008 - 20:58
Try/check this code
