VPN client fot Nokia E90
balsheikh
I'm trying to find a VPN client supported on Nokia's mobiles E series specifically and compatible with Cisco ASA as VPN termination point.
Any useful comments will be appreciated..
JORGE RODRIGUEZ
Level 10
Level 10
Check 3rd party vpn clients that supports the standard Ipsec and that run on Nokia E series OS,compatibility is based on IPsec standards. Try google and do a search for vpn client for nokia mobiles, have you checked nokia to see if they have develope a vpn client for the device? probably your best bet is to check Nokia forums out there.
good luck
Rgds
Jorge
Jorge Rodriguez
I've digged on Internet and went thru google to no avail, i didn't find an individually VPN client installed and configured to operate independent of server manager, actaullt this is out of my scope of work.
I'm looking for stand alone VPN client supported on Nokia E90 and applicable with Cisco ASA.
VPN client for Nokia E90 is available now at http://www.businesssoftware.nokia.com/mobile_vpn_downloads.php
It should work with Cisco ASA
-pasi-
