Warning message
dial-peer load balancing
Jan 20th, 2008
hi.
I do below configuration in a (C) router.
A Router and B router was connected
the same PBX(number 5555).
A(1.1.1.1) ----------|
|-(C)
B(2.2.2.2) ----------|
(C) router configuration.
dial-p 1 v voip
destination-p 5555
sesion target ipv4:1.1.1.1
dial-p 2 v voip
destination-p 5555
session target ipv4:2.2.2.2
1.1.1.1(A) and 2.2.2.2(B) is not same router.
when i configure other dial-peer for same number(5555),
I checked call session was balanced to the two router.
for the example,
first call go to the A router.
second call go to the B router.
is this normal symptom?
like acl rule
i want to know dial-peer match rule.
paolo bevilacqua Sun, 01/20/2008 - 10:28
  • Hall of Fame,
    Founding Member
Yes, without a configured preference, calls will go round-robin. You can change that wiht "dial-peer hunt " - type ? to see the possible choices.
