Joe Clarke Sun, 01/20/2008 - 10:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can do this under RME > Config Management > Netconfig > User-defined Tasks. If all your commands will be the same for the group of devices, then creating a new task is trivial. Just enter the commands you wish to deploy. If, however, some commands will be different from some of the devices, you will need to create a parameterized task. Consult the online help from the User-defined Tasks screen on how this is done.
