1 subnet split over 2 locations?
Answered Question
Jan 20th, 2008
Hi we have a subnet which for clustering purposes must be split across 2 different locations connected via a leased line.
At the moment we are spanning 1 vlan across the two switches at either end via a trunk.
However if we lose the trunk connection we can still reach the remote site via layer 3 access (as the site has more than one connection) but the trunk goes down along with the link therefore full connectivity is lost.
Can anyone suggest a better way to split one subnet across the two sites? We cannot put another connection in and we cannot use a trunk via the other l3 links either as this would mean a major reconfuguration of the current set ups.
Any help would be great
thanks
Jonathan
Correct Answer by Jon Marshall about 9 years 1 month ago
Jonathan
As far as i know unfortuntely not, at least i haven't come across it before. It might be worth checking the Pix release notes just in case.
Edit - bear in mind that it is using tunneling so there is no reason why you couldn't use 2 routers and tunnel through the pix firewalls but that depends on your security policy really.
Jon
Overall Rating: 5 (1 ratings)
jmoss1@preston.... Mon, 01/21/2008 - 04:02
Hi Jon, thanks for the reply this is great. However do you know if I could set this up using 2 x cisco pix 515E's rather than a router?
Cheers
Correct Answer
Jon Marshall Mon, 01/21/2008 - 04:08
Jonathan
Jon
