2960 etherchannel to 4948
Answered Question
Jan 20th, 2008
I have an etherchannel that does seem to be [assing traffic between the two gig ports on a 2960 and two gig ports from a 4948. When I created the extherchannel on the 2960 there didn't seem to be an option to type the command
Am I missing something?
Thanks in advance
Correct Answer by Edison Ortiz about 9 years 3 months ago
When you only have one trunking option, you don't need enter dot1q. You need to enter dot1q when the switch supports ISL and 802.1q.
The 2960 only supports 802.1q, you can verify the trunking status by typing show interface fx/x switchport
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
william.briere Sun, 01/20/2008 - 10:16
should read "doesn't seem to be passing traffic between the two gig ports"
william.briere Sun, 01/20/2008 - 10:21
I had vtp set to server for some reason... So my management network wasn't reachable??? LOL
Have a great day netpros
glen.grant Sun, 01/20/2008 - 10:21
  • Purple, 4500 points or more
That is the only type of encapsulation it supports so its the default and you don't have to set it . It does not support ISL for trunks...
Correct Answer
Edison Ortiz Sun, 01/20/2008 - 10:22
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
