The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
How can I speak to an Allegiant Air representative fast?Talk to someone on Allegiant Air smoothly, give their dedicated support line a ring at + ퟏퟖퟎퟓ ퟑퟎퟗ ퟗퟑퟕퟕ . Take your time and listen carefully to the automated prompts, then share all the required...
헔헺헲헿헶헰헮헻 헔헶헿헹헶헻헲's phone number to call and talk with a live 헿헲헽헿헲혀헲헻혁헮혁헶혃헲 fast is ퟭ-ퟴퟬퟰ-ퟮퟱퟭ-ퟴퟴퟴퟲ // ퟭ-ퟴퟬퟰ-ퟮퟱퟭ-ퟴퟴퟴퟲ. Select your connection language upon call and choose the IVR option that best suits your query by looking through the ones that are ...
Hello Community, I'm writing to let you know that there is a critical POE defect in the CBS350 switches and you should avoid them if you require stable POE operations. This apparent software defect causes POE ports to randomly fault after 8 to 12 hou...
How can I speak to an Allegiant Air representative fast?Talk to someone on Allegiant Air smoothly, give their dedicated support line a ring at + ퟏퟖퟎퟓ ퟑퟎퟗ ퟗퟑퟕퟕ . Take your time and listen carefully to the automated prompts, then share all the require...
Hello all,I'm trying to make sure I understand the procedure for refreshing our current L2 APIC's with our new L4 APIC's.Currently our fabric is running 5.2(4) , and the new L4 APIC's require either 5.3 or 6.0.5 (which has just come out and is what w...
Calling all Cisco CX Cloud users even all Cisco customers and partners! Are you fully leveraging Cisco CX Cloud to: Reduce 2-5 mins/case from your case management time Automates case opening and processing (RMA); Reduces duplication and false...
Hello,I've been planning to role out dot1x on my network. However, the network consists of NXServers in the DC with thin clients that connect back them at user desks.As I think about it, how would dot1x work in this environment? Connecting a PC to a ...
Greetings! Hope somebody can guide me how is it supposed to be done! Sorry, I'm a noob and seems to can't find an answer.Lets say I have 3 subnets/vlans/interfaces with security levels:inside (90)dmz (10)outside (0)lets say I want to allow http/https...
Hello, I can't manage to give the connected PCs an ip through the dhcp server. My packet tracer + network design are attached. Have currently only started on the bottom part so it's only about the bottom PCs.Thanks in advance for the effort
After upgrading the CSPC collector from version 2.10.0.3 to 2.10.0.7, the adminshell is no longer accessible. When trying to log into the admin CLI with the admin account, the credentials are accepted, and then it immediately goes back to the login ...
I have a less then a dozen Cisco 3850 switches that I am working on. I need to configure 802.1x authentication. The issue is the switches are reaching out to Cisco ACS and I need to set up radius server to enable 802.1x. The Cisco ACS I found out ...
Hello all, Quick bit of background on this, the way our contact center currently works is that they have 1 line on their phones which they take both direct calls and calls via CSQ's. They have a few reports that they are using at the minute that incl...
