Voice-Translation Rule
Jan 20th, 2008
Hi have configure a voice port that is connected to a fax to prefix the caracter 'F' to all incoming fax call. If i configured the folowing translation-rule the call goes to the pstn:
Translation Rule for prefix the F character in the fax voice-Port
translation-rule 1
Rule 1 ^. F
voice-port 2/0/0
translate called 1 !Translation for prefix the F caracter
compand-type a-law
cptone PT
description FAX port
station-id number 210007
dial-peer voice 8203 pots
corlist outgoing AFTER-HOURS
description CONN-AFTER-HOURS-FAXES
paramspace callsetup after-hours-exempt TRUE
destination-pattern F0[23789]........
direct-inward-dial
port 2/0/8
forward-digits 9
If I change the translation-rule to a voice translation-profile, the call is disconnected after I hit the first digit:
voice-translation rule 9
rule 1 /^/ /F/
voice translation-profile PREFIX-F-AFTER-HOURS-FAX
translated called 9
voice-port 2/0/0
translation-profile incoming PREFIX-F-AFTER-HOURS-FAX
compand-type a-law
cptone PT
Can any one give me same help.
paolo bevilacqua Sun, 01/20/2008 - 14:18
  • Hall of Fame,
    Founding Member
Try:
rule 1 // /F/
