ASA5520 support with RME ver 4.0.5
Answered Question
Jan 20th, 2008
Running LMS 2.6. ASA5520 is detected with Common Services 3.0.5 but RME ver 4.0.5 does not detect the ASA. Is there a patch for this?
Correct Answer by Joe Clarke about 9 years 1 month ago
The best solution is to upgrade to CS 3.0.6 and RME 4.0.6 via Common Services > Software Center > Software Update. This way, you'll get the new RME device packages (including ASA support) as well as bug fixes. However, there is a device package available for ASA by going to Common Services > Software Center > Device Update. Check both Common Services and Resource Manager Essentials, and download all available updates.
Overall Rating: 4.5 (2 ratings)
Correct Answer
Joe Clarke Sun, 01/20/2008 - 15:36
