Upgrade MDS 9506 from 3.0(3c) to 3.2(2c)
Answered Question
Jan 20th, 2008
After the updgrade, I received from the callhome 34 emails each 2 hours :
Severity Level:2
source:MDS9000
Switch Priority:4
Device Id:[email protected]@FOX1031037L
Server Id:[email protected]@FOX1031037L
Time of Event:2008-01-20T23:27:42
Message Name:RMON_ALERT
Message Type:RMON
System Name:MTLSANSW1
Contact Name:adminunix
Contact Email:[email protected]
Contact Phone:+514-848-5096
Street Address:395 de Maisonneuve Blvd. West Event Description:WARNING(4):iso.3.6.1.2.1.2.2.1.16.16801792=8086132 >= (90, 0):10, 4 ThresholdType:RisingThreshold ThresholdValue:90
AlarmValue:8086132
start chassis information:
Affected Chassis:DS-C9506
Affected Chassis Serial Number:FOX1031037L Affected Chassis Hardware Version:2.0 Affected Chassis Software Version:3.2(2c) Affected Chassis Part No:73-8697-03 end chassis information:
Thanks for your help !
Correct Answer by stephen2615 about 9 years 5 months ago
Somehow or another, you are getting RMON events from the switch. I don't know why you are getting them as I believe they should be configured not set as default. Check out the following link:
http://www.cisco.com/en/US/products/ps5989/products_configuration_guide_chapter09186a00806630f7.html
If you don't want them, turn them off.
1(iso).3.6.1.2.1.2.2.1.16 is ifOutOctets or the amount of traffic going out of an interface (even though I don't know what interface 16801792 could be). I would not be concerned about it. 8086132 octets is probably just 8 MB's per second or 64 Mbps which is a lot less that 2 Gpbs..
Cheers
Stephen
Overall Rating: 5 (1 ratings)
Correct Answer
stephen2615 Mon, 01/21/2008 - 01:37
  • Bronze, 100 points or more
Cheers
Stephen
Trending Topics: Storage Networking
