Error message on booting up 3550 switch
Jan 20th, 2008
My Cisco 3550 switch is booting up with the following error message:
!!! Warning the switch is not usable !!!
It does not list a reason
It then goes into Rommon, what are the possible causes of this error message. The switch is a WS-C3550-24PWR-SMI
Richard Burts Sun, 01/20/2008 - 18:35
Perhaps if you posted all of the messages sent to the console during the boot process we might have a better insight into the problem. I would think that the most likely cause of this error message would be a hardware problem with the supervisor. I would also guess that a problem with flash which prevents booting might also cause a similar problem.
In either case the thing to do is to open a case with Cisco TAC about the problem.
smothuku Mon, 01/21/2008 - 01:45
Hi ,
switch off the 3550 switch and coonect console cable to the sswitch.
Try to capture all the console messages after turning on the switch.
