BGP
Jan 20th, 2008
Guys we have three methods to filter routes in BGP(correct me if i m wrong) first one is distibute list second is route maps and third is prefix-list.....what is the diference between them
royalblues Sun, 01/20/2008 - 23:33
All of them more or less achieves the same thing except for route-maps which gives you more felxibility and can reference a prefix-list, access-list etc and also set attributes
Narayan
Pavel Bykov Mon, 01/21/2008 - 02:34
Every method filters using it's own technique. What is important is their sequence, which is reversed for outbound and inbound updates.
On Inbound:
1. Prefix List
2. Filter List
3. Route Map
4. Distribute List
On Outbound:
1. Distribute list
2. Route Map
3. Filter list
4. Prefix List
From the other routing process inside the router:
1. Filter List
2. Distribute List
3. Default Weight
4. Filter-list weight
5. Route maps
Hope this helps.
Please rate all helpful posts.
