Where is the startup-config held ? - NPE-300 or I/O controller
Jan 20th, 2008
In a Cisco 7206VXR router that has a NPE-300 and and I/O controller I undertand that the IOS is on a PCMCIA card which is installed on the I/O controller. Is the config also held on the I/O controller or is it held on teh NPe-300. When we put a NPE-G1 I understand that an I/O controller is not required and that the the IOS and config are held on NPE-G1.
To ask the question in another way - If we replace the NPE-300 module does the startup config need to be loaded into the new NPE-300?
Overall Rating: 4.5 (2 ratings)
plumbis000 Sun, 01/20/2008 - 22:56
I believe the NVRAM is stored on the I/O Controller on all NPEs except the G1 and G2.
