Error on router
Answered Question
Jan 20th, 2008
Hi Everyone,
I have a nagging issue with one of my routers which I used for my CCNA exams. Whenever I log into it while waiting at the exec prompt the following error is notified:
%Error opening tftp://255.255.255.255/network-confg (Timed out)
%Error opening tftp://255.255.255.255/cisconet.cfg (Timed out)co
%Error opening tftp://255.255.255.255/lagos.inetlynx-confg (Timed out)
%Error opening tftp://255.255.255.255/lagos.in.cfg (Timed out)
This started when I mistakenly erased the content of the flash but since I resolved the problem with the flash, that is, reinstalled the IOS I've been getting this nagging error. Any assistance reandered will be appreaciated.
Concerned Admin
Correct Answer by royalblues about 9 years 1 month ago
USe the command " No service config" under the global configuration mode to avoid these error messages
Narayan
Overall Rating: 5 (1 ratings)
Correct Answer
royalblues Sun, 01/20/2008 - 23:56
Narayan
massimiliano.se... Mon, 01/21/2008 - 00:03
The router, viewing these messages, take the configuration file in a server tftp not accesible; or the file is not accessible for read.
You've probably specified this using the command: boot host.
View, for more information, boot config e boot host.
http://www.cisco.com/en/US/docs/ios/12_0/configfun/command/reference/frcfgfil.html#wp1017539
I hope this helps.
Best regards.
Massimiliano.
cyberpimp28 Tue, 01/22/2008 - 17:22
Thank you for your reference it didn't solve the problem but hey it taught me something new.
