which mode is working
Jan 21st, 2008
In my network cisco IPS is working act as an IDS mode.
have any command that without see the physical connectivity and known the mode to see the IPS working as IDS mode or IPS mode or if have no like this command then BY IDM i can get the infrmation ?
Biplob
Overall Rating: 4 (1 ratings)
Yes, many commands can show this:
sensor# sh stat virtual-sensor
can give you a hint:
List of interfaces monitored by this virtual sensor = Pair1 subinterface 0
for IPS mode and:
List of interfaces monitored by this virtual sensor = FastEthernet0/1 subinterface 0
for IDS mode.
Or use:
S1# show interfaces brief
CC Interface Sensing State Link Inline Mode Pair Status
* FastEthernet0/0 Disabled Up
FastEthernet0/1 Enabled Up Unpaired N/A
FastEthernet1/0 Disabled Down Unpaired N/A
FastEthernet1/1 Disabled Down Unpaired N/A
FastEthernet1/2 Disabled Down Unpaired N/A
FastEthernet1/3 Disabled Down Unpaired N/A
for IDS mode or:
FastEthernet0/1 Enabled Up Paired with interface FastEthernet1/0 Up
FastEthernet1/0 Enabled Up Paired with interface FastEthernet0/1 Up
for IPS mode.
Or use setup.
