Problems connecting to exchange server through VPN
Jan 21st, 2008
I use Cisco VPN client version
5.0.0.1.0600 over a cellular line. Telenor 3G. I use a Nokia E65 with nokia PC suite and standard bluetooth modem.
The tunnel connects and all is well until I open Outlook. I get prompted for a username/password. None of the usernames work. I tried everything from domain admin to testuser. I get the following error:
http://img155.imageshack.us/img155/7406/46816658fr7.jpg
It works fine with VPN over xDSL. Does anyone know what's up?
simenringstad Mon, 01/28/2008 - 03:26
If it is a certificate error, why does it work on xDSL and when I use a windows mobile with connection sharing over bluetooth or cable?
jag_robert Tue, 02/05/2008 - 01:33
For info. VPN Client 5.0.02.0090 has the following resolved issue stated in the readme-file:
Resolved Issues:
CSCsh15103 Client using a Digital Cert cant connect thru a Cable/DSL router
It's the opposite of your problem but might be worth a try anyway?
Also, have you tried the usual MTU change to 1300. Outlook have problems if there are any MTU issues on the way.
//Rob
