Grouping PRI Channels
Answered Question
Jan 21st, 2008
Friends,
I am working on voip setup where Ericsson PBXs are connected with cisco 3800
routers. You can see topology below:
Phones-------PBX-A----Router-A-------------------------Router-B------PBX-B--------Phones
PBX is connected with router through E1 Pri (qsiq) where as Router are
connected via E1 link.
Issue is: before voip setup PBXs are connected point to point and TDM
engineer divided channels in to two groups. One from channel 1-18 for
subscribers and other from 19-31 for Operators. So when subscriber come on
trunk, it was assigned channel from 1-18 and operators are assigned channel
from its range. Now i put routers between PBXs so when operator of PBX-A try
to dial number, operator is assigned channel from its range on PBX-A and
forward to Router-A. When that call reaches Router-B, it assign first
available channel on pri that is connected with PBX-B. But we want channels
are assigned by Router-B must be same that assigned by PBX-A.
Hope you will have understand my problem. And please tell me the
solution.......You immediate response will be appreciated.
Best Regards
Rameez
Correct Answer by Paolo Bevilacqua about 9 years 3 weeks ago
You can use either a COR config, or "prefix digits".
In both cases you configure an incoming DP that with "answer-address" that matches number from operator, or other numbers.
With COR, you set corlist so that the ougoing DP is chosen based on COR config.
With "prefix digits", you use translation-profile so that some digits are added then removed, and the call is routed by these digits. See:
http://cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801c0a88.shtml
Correct Answer by pcameron about 9 years 1 month ago
Providing you use the gateway in H323 mode, you can use a new trunk group feature that allows you to specify individual timeslot members.
Here is an old config I got working a while back, it is relevant to your application and it should show you how to make your system work. Since you don't have a call manager, ignore the comments about route patterns. In your case, you would use a matching trunk group config on router B to direct calls to the outgoing trunk groups that correspond to the timeslots.
For ISDN -
controller E1 1/0
pri-group timeslots 1-31
trunk-group Channel_1 timeslots 1
trunk-group Channel_2 timeslots 2
trunk-group Channel_3 timeslots 3
trunk-group Channel_4 timeslots 4
trunk-group Channel_5 timeslots 5
.... (leave out D channel timeslot 16)
trunk-group Channel_31 timeslots 31
dial-peer voice 1 pots
description - enable DID on group 1
incoming called-number .
direct-inward-dial
trunkgroup Channel_1
dial-peer voice 2 pots
description - enable DID on group 2
direct-inward-dial
trunkgroup Channel_2
dial-peer voice 3 pots
description - enable DID on group 3
direct-inward-dial
trunkgroup Channel_3
dial-peer voice 4 pots
description - enable DID on group 4
direct-inward-dial
trunkgroup Channel_4
dial-peer voice 5 pots
description - enable DID on group 5
direct-inward-dial
trunkgroup Channel_5
dial-peer voice 31 pots
description - enable DID on group 31
direct-inward-dial
trunkgroup Channel_31
dial-peer voice 771 pots
description - Channel_1 : access code 771
destination-pattern 771
dial-peer voice 772 pots
description - Channel 2 : access code 772
destination-pattern 772
dial-peer voice 773 pots
description - Channel 3 : access code 773
destination-pattern 773
dial-peer voice 774 pots
description - Channel 4 : access code 774
destination-pattern 774
dial-peer voice 775 pots
description - Channel 5 : access code 775
destination-pattern 775
dial-peer voice 7731 pots
description - Channel 31 : access code 7731
destination-pattern 7731
On the CCM, you need to run H323 as the gateway signaling protocol
To make outwards calls, users would dial the particular number that corresponds to a channel on the PRI. The CCM route pattern would have a specific match on this string. For example, a user wants to make a call out on timeslot 1. They would dial the unique access code (771) and the rest of the number/s , which corresponds to a route pattern on the CCM. This access code would not be stripped from the dialed number sent to the H323 gateway. Since we have a specific dial peer that matchs on '771, the call is sent out on trunk group 'Channel_ 1' , which corresponds to timeslot 1. The 771 is stripped off by the outgoing POTS dial peer and the rest of the number is sent out the PRI.
For channels 2 to 31, users would dial the relevant number, and this would match on the other unique CM route pattern strings. The call would be treated similar to the above.
Overall Rating: 5 (3 ratings)
Paolo Bevilacqua Mon, 01/21/2008 - 05:34
In QSIG/PRI on cisco IOS, you cannot divide a same circuit in groups. It is not like using E1-R2 that allows such a logical division. So, in short, you cannot preserve channel order between PBX calls , not withstanding that, everything should work anyway, as you can for example limit the number of calls at DP level.
Now, if you want to avoid discussing with the PBX technicians and customer, configure T-CCS that will transport D-chan and B-chans unaltered. There are configuration examples on CCO on how to do this.
The disadvantage, is that you will need to configure VAD to prevent the B-chans to be open all the time!
Correct Answer
pcameron Mon, 01/21/2008 - 06:42
For ISDN -
controller E1 1/0
direct-inward-dial
direct-inward-dial
direct-inward-dial
direct-inward-dial
direct-inward-dial
direct-inward-dial
Paolo Bevilacqua Mon, 01/21/2008 - 08:09
Paul,
Which platform is that?
On a 3821 with 12.4(11)XW5 I don't have trunk-grup under controller E1:
BA-CCME(config)#controller E1 0/0/1
BA-CCME(config-controller)#?
Controller configuration commands:
cas-custom cas group customization configuration
channel-group Specify the timeslots to channel-group mapping for an
interface
clock Specify the clock source for a DS1 link
default Set a command to its defaults
description Controller specific description
detect Enable detection of loopback request
ds0 ds0 commands
ds0-group Configure group of timeslots to a particular signaling type
exit Exit from controller configuration mode
framing Specify the type of Framing on a E1 link
guard-timer Guard timer (0-20) for xcsp calls - timer duration and
accept/reject on expiry
help Description of the interactive help system
line-termination Specify the line termination for E1
linecode Specify the line encoding method for a E1 link
loopback Put the entire E1 line into loopback
mode Configure the controller mode
no Negate a command or set its defaults
pri-group Configure the specified timeslots for PRI
shutdown Shut down a E1 link (send Blue Alarm)
snmp Modify SNMP controller parameters
tdm-group Configure DS0 group for TDM
pcameron Mon, 01/21/2008 - 15:36
Just tested this on a 2851 running 12.4.11T, IP voice feature set.
You need to configure the pri-group first, otherwise the CLI parser won't allow the trunk-group command -
controller E1 0/0/0
pri-group timeslots 1-10
CME-Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
CME-Switch(config)#controller e1 0/0/0
CME-Switch(config-controller)#trunk-group ?
WORD Trunk group label
Paolo Bevilacqua Tue, 01/22/2008 - 03:40
Hi, I do have pri-group. Do you have VWIC or VWIC2 ?
CT-CCME#sh run | b controller
controller E1 0/2/0
pri-group timeslots 1-20
CT-CCME#sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPVOICE-M), Version 12.4(11)XJ4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 13-Jul-07 22:43 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
CT-CCME uptime is 4 days, 3 hours, 51 minutes
System restarted at 08:42:20 CET Fri Jan 18 2008
System image file is "flash:c2800nm-ipvoice-mz.124-11.XJ4.bin"
Cisco 2851 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FCZ105072QA
2 Gigabit Ethernet interfaces
20 Serial interfaces
4 ISDN Basic Rate interfaces
1 terminal line
1 Channelized E1/PRI port
4 Voice FXO interfaces
11 Voice FXS interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
CT-CCME#sh diag
PVDM Slot 0:
48-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8540-05
Board Revision : A0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC10435CFM
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-48
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 ED 41 04 00 82 49 21 5C 05 42 41 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 30 34 33
0x20: 35 43 46 4D 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 34 38 89 56 30 31 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 2:
E1 (1 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0 Board revision B0
Serial number 35293166 Part number 800-04475-04
FRU Part Number VWIC-1MFT-E1=
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 21 01 00 02 1A 87 EE 50 11 7B 04 00 00 00 00
0x30: 58 00 00 00 06 10 05 00 FF FF FF FF FF FF FF FF
CT-CCME#conf t
CT-CCME(config)#controller E1 0/2/0
CT-CCME(config-controller)#trunk-group ?
% Unrecognized command
pcameron Tue, 01/22/2008 - 04:49
not sure what is going on here, here is the router I am testing with -
CME-Switch(config-controller)#do sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPVOICE-M), Version 12.4(11)T, RELEAS
E SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 18-Nov-06 17:16 by prod_rel_team
CME-Switch uptime is 17 weeks, 4 days, 3 hours, 45 minutes
System image file is "flash:c2800nm-ipvoice-mz.124-11.T.bin"
Processor board ID FHK1120F300
88 Serial interfaces
33 terminal lines
8 Channelized E1/PRI ports
6 Voice FXO interfaces
16 Voice FXS interfaces
CME-Switch(config-controller)#?
interface
ds0 ds0 commands
trunk-group Configure interface to be in a trunk group
CME-Switch(config-controller)#trunk-group test ?
timeslots Add specific timeslots into trunk group from signaling interface
CME-Switch(config-controller)#trunk-group test timeslots ?
<1-16> List of timeslots to configure under trunk group
CME-Switch(config-controller)#trunk-group test timeslots 1-10 ?
preference configure the preference for DS0 trunk group
E1 interface is a VWIC-2MFT-E1
WIC Slot 0:
E1 (2 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0 Board revision C0
Serial number 35642695 Part number 800-04479-04
FRU Part Number VWIC-2MFT-E1=
Connector type PCI
0x20: 01 23 01 00 02 1F DD 47 50 11 7F 04 00 00 00 00
0x30: 60 00 00 00 07 04 09 00 FF FF FF FF FF FF FF FF
can you try with a two port e1 card ?
Paolo Bevilacqua Thu, 01/31/2008 - 08:10
I got the time to try that again. A 3845, with latest 12.4 mainline, then 12.4(11)XJ4, tried VWIC-MFT 1 and 2 ports.
All gave no problem. I have no idea what is preventing me from configuring on the other box.
Thanks!
rameezsardar Thu, 01/31/2008 - 09:40
Dear p.bevilacqua,
Ahan. that may be some configuration issue. I am also using this trunk-group on 3800 router. I knew this command before but i just knew that it used for bundling interfaces but didn't know to use it in this way.
rameezsardar Wed, 01/23/2008 - 03:38
Dears,
I have vwic-2mft-2t1/e1, vwic2-2mft-2t1/e1 and nm-hdv2 but i could not check configuration......
get you later
rameezsardar Thu, 01/24/2008 - 09:14
Dear,
Bundle of thanks your suggested method is working fine. I configure trunk-groups and assigned channel to them. Everything is ok.
Best regards
rameezsardar Thu, 01/31/2008 - 09:43
Brothers,
I need your assistance again. I have created two trunk group one "sub" for subscriber and other "opr" for operator. Now issue arise that i have to forward calls so that if call come from sub trunkgroup on router1, on router2 it must forward on sub trunkgroup and same for opr trunkgroup. You can see topology below:
PhoneA----- PBX 1------------Router1-----------Router2---------PBX2---------PhoneB
Please tell me the way how can i do that.
Waiting for positive immediate response..
Best Regards
Correct Answer
Paolo Bevilacqua Fri, 02/01/2008 - 06:01
rameezsardar Wed, 02/06/2008 - 23:57
Dear P.Bevilacqua,
Thanks for your responding. Translation-profile solve my issue. Everything is working fine. Can we also use COR for this purpose? To the best of my knowledge, COR can only be used for allow/restrict calls.
Best Regards
Paolo Bevilacqua Thu, 02/07/2008 - 03:52
the technique when using COR, is like that:
call comes in, and is associated with a COR peer, or to no COR at all, via incoming DP.
When it goes out, it will try the matching DP with better preference. Now, if said DP is blocked by COR, call it will re-hunt to next matching DP. If COR allows, the call will be placed using the appropriate trunk-group.
This technique allows eliminating the steering digits and translation-profiles.
