multiple gateway configuration
Jan 21st, 2008
Hi all,
I've got an 1811 router with two DSL connections. I need to seperate the VPN and email traffic, each must go through the designated wan-link. Can I manage that with access lists or is there some other way to do it? Thanks in advance...
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 01/21/2008 - 05:58
Yes you can do this using PBR (Policy Based Routing) which allows you to set the outgoing interface/next Hop ip addresses based on source and destintation IP addresses together with TCP/UDP ports.
Have a look at this config document for PBR and come back with any queries.
