CNR DEX (C++ Compiler) dynamic library problem.
Jan 21st, 2008
Hi, I need some help with CNR DHCP DEX extensions C++.
I have a dynamic library developed in C++. If this library is compiled with CC (Sun Studio 10: C++ 5.7 Compiler), the DHCP can't load it, and it doesn't give more information about the problem. It just says 'unable to load...'.
But, if I compile the same library with g++, the DHCP loads it successfully.
Any idea?
Thanks to all.
aghaznavi Fri, 01/25/2008 - 10:02
  • Silver, 250 points or more
Better you rebooting the machine and starting CNR afresh
lucasvaldez Mon, 01/28/2008 - 04:58
Thks aghaznavi. The problem is that the run time C++ compiler isn't installed. I coded a C program with dlopen, dlsym, etc. that calls a C++ program. Then I added this C program to CNR extensions and get the dlopen error.
Sorry for my english :)
