"Ring Out" shown on IP Phone but no ringing tone
eug-c
I am having a problem where i have a QSIG connection between a Cisco 3845 and a Nortel Option 11C PBX. This router is configured as H323 registered to a CallManager 4.2(3)
When I use an IP phone and dial to a nortel phone.
The nortel phone is ringing, but I do not hear the ringing on the IP phone. There is a message "Ring Out" on the IP phone.
When I do a debug isdn q931 on the router, this is what I see:
Router#
Jan 21 23:33:36 SG: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 83181713
Jan 21 23:33:36 SG: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Called num 1708
Jan 21 23:33:36 SG: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0006
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0081, '1000'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '2000'
SGHQGA2-3845#
Jan 21 23:33:36 SG: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8006
Jan 21 23:33:36 SG: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8006
Jan 21 23:33:36 SG: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8006
Locking Shift to Codeset 5
Codeset 5 IE 0x32 i = 0x81
Here is a partial Configuration of the QSIG connection.
interface Serial0/1/0:15
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache cef
no ip route-cache
no logging event link-status
isdn switch-type primary-qsig
isdn protocol-emulate network
isdn incoming-voice voice
no isdn T309-enable
isdn T310 120000
no cdp enable
Hope someone can help on this.
Eugene
PETER NEGUS
This may be that old chestnut "isdn progress indicators". Try
progress_ind alert enable 8
under the outbound dial peer.
You may also need
progress_ind setup enable 3
on the inbound dial peer if there are ringback problems the other way
Thanks both, I will try this out. :)
Appreciate it.
Eugene
Thanks!
The progress_ind solved the problem.
The H225 service parameter had no efffect.
Thanks all!
learnt something today.
Eugene
