How do you change voice speed for IPIVR with Nuance TTS
Answered Question
Jan 21st, 2008
IPIVR 4.0(5) with external Nuance TTS server. I'm trying to change the voice speed as it is too fast. I am told I need to use SXML in CRS. Don't have any clue how to do this at all. Anyone?
Correct Answer by BCOLE2007 about 9 years 3 months ago
Try this to set your default rate
1)Navigate to your MRCP server config file
or search for OSSserver.cfg on your TTS server
2)Open the file
look for defaultRate
change the number on this line to something lower than what it is, the default is 50
save the file
3)Restart the service SpeechWorks MediaServer
on the TTS server
the new rate should take affect, some may complain of a 'gurgling' sound in some words on the voice
we have bounced back between 50 to 35, now at 45
let me know how it turns out
and don't forget to rate posts
Blair
Overall Rating: 5 (1 ratings)
Riccardo Bua Mon, 01/21/2008 - 13:59
  • Cisco Employee,
Hola,
I would assume you are using Vocalizer 3.x.
By modifying a Nuance configuration file, cf02_appcfg.txt, we can alter the
speed. But this value will affect both the genders, we do not have the
ability to change the speed for each voice. The tag to be modified in this
file is SPEAK_RATE. The default setting is 100. Nuance suggests using a
range of 50 through 150. A value of 50 means the speech duration will be
half that at 100. The value of 150 means the duration will be 50% longer
than that at 100.
For en-US voice used in North America, the .txt file to be modified is
located under c:\Nuance\Vocalizer3.0\data\en-US\config\mulaw. The engine
needs to be restarted after these changes are made.
To work with provisioning your system with some scripts please refer to the Dev Guide:
http://www.cisco.com/application/pdf/en/us/guest/products/ps6488/c1626/ccmigration_09186a00804a2b0d.pdf
Riccardo
PS. Please remember to rate useful posts
SAN J Mon, 01/21/2008 - 14:25
Thanks Riccardo. The Nuance App I'm using is actually RealSpeak 4.X. I would hope there is an equivalent config file I can edit to change the speed rate? I'm not onsite so I can't check it quickly but I will when I get a chance.
Correct Answer
BCOLE2007 Thu, 01/24/2008 - 12:25
  • Bronze, 100 points or more
2)Open the file
save the file
on the TTS server
Blair
