Ciscoworks Device Discovery
paul.coley
We currently use a product called IND Peregrine Network Discovery and it discovers based on SNMP and has no issue with dicovery via NAT. Since I am building this new Ciscoworks server and I would like to know if I can import the device database from this third party product into Ciscoworks LMS 2.6
This would possibly save me a tonne of manual work regarding playing around with seed file and local host file.
David Stanford
This isn't a supported product for third party integration, but if this program allows you to export your devices (and credentials) to csv file then you can import this csv file into LMS.
Of course, if will only support Cisco devices.
