ankbhasi Mon, 01/21/2008 - 09:13
  • Cisco Employee,
Hi Zeeshan,
May be I am not able to understand your problem? Can you please rephrase and explain?
You created vlans in vlan database? and then you configured trunk on some physical port? and then whose status goes down? trunk status? Is something connected on trunk port?
Ankur
glen.grant Mon, 01/21/2008 - 11:20
  • Purple, 4500 points or more
If you are talking about the layer 3 SVI's then you can only have one active SVI (interface vlan X) . This is to manage the switch only so you can only have 1 active at a time. If it is some other issue please explain .
zeeshan.a Tue, 01/22/2008 - 05:09
hi
let me explain u in detail
i am creating 4 VLANs on 2924XL switch, the trunk port issue has been solved
bt only VLAN 1 is not shutdown, the other vlans automaticaly shutdown.
i am giving ip address to vlan 1 only, while the other vlans are not assigned any ip...
do let me know if need further info..
thnx in advance
ankbhasi Tue, 01/22/2008 - 05:38
  • Cisco Employee,
Hi Zeeshan,
Is your concern that only vlan 1 is active and other vlans are automatically shutdown?
If yes that it is expected behavior because 2900XL switches are layer 2 switches and only one layer 3 interface can be active at a time just for management purpose other layer 3 interfaces will be shutdown automatically by an IOS.
If your concern is something else please come back.
Ankur
*Pls rate all helpfull post
