01-21-2008 09:42 AM - edited 03-18-2019 08:21 PM
hi,
I would like to know if somebody knows how i can fix the issue of data range on a callmanager 5.x ? I have found solutions for 3.x or 4.x only, like the link below: http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K83216461
Solved! Go to Solution.
01-22-2008 07:37 AM
Hi Guilherme,
I think you may be hitting one of these bugs which both give the Error 30023;
CSCsl69542 Bug Details
CAR not able to load CDR flat files after W1 migration
Symptom:
After upgrade from callmanager 4.x to callmanager 6.0.1, CAR is not able to load CDR flat files into CAR DB.
Conditions:
Upgrade from callmanager 4.x to callmanager 6.0.1 with CAR
Workaround:
Run the following queries fro CLI:
Run sql Select max(Error_Record_Id) from car:tbl_error_id_map
returned
Get the result of above query as and run the following:
Run sql update car:tbl_system_preferences set param_value= where param_name='MAX_ERROR_RECORD_ID'
for example, if "max(Error_Record_Id) from car:tbl_error_id_map" return 100, then please update 'MAX_ERROR_RECORD_ID' as 101.
Further Problem Description:
When CDR load failed, in CAR scheduler traces,
ERROR [DailyCdrLoad] beans.EBErrorIdMap -save(): SQL Error while saving data java.sql.SQLException: Unique constraint informix.pktbl_error_id_map_01) violated.
is found.
1st Found-In
6.0
Fixed-In
6.0(1.2120.1)
7.0(0.39000.6)
5.1(3.1111.1)
CSCsk99713 Bug Details
Loader does not start until next schedule if it is detected running
Symptom:
CAR loader does not start until its next schedule time. If 'Continuous Loading 24/7' is
enabled and such timing/racing condition happens, loader will skip at most up
to 24 hours of a window for loading CDRs/CMRs. Hence new records will have a
delay to be loaded into CAR database for reporting.
Note: Besides "DailyCdrLoad", this condition can happen to: "DatabaseAlert" or
"DeleteReports" or "DatabaseMaintenance" or "TaskMonitor", although the chances
are less than "DailyCdrLoad" loader.
Conditions:
This is an interim case and should not happen very often. And tt's likely to happen
if we have 'Continuous Loading 24/7' enabled and running for days or weeks.
Workaround:
Simply restart 'CAR Scheduler' service, if one suspects a delay on CDR loading
caused by this issue.
If waiting or delay is not an issue, the workaround can be simply do nothing,
and scheduler will reschedule things (repouplate schedules) again in midnight 00:00,
and loader will start off to load CDRs again every midnight continuously.
1st Found-In
6.1
5.0
5.1
6.0
Fixed-In
6.1(0.9901.430)
5.1(3.9901.22)
6.1(1.1000.11)
Hope this helps!
Rob
01-22-2008 07:37 AM
Hi Guilherme,
Symptom:
Conditions:
Workaround:
returned
is found.
1st Found-In
6.0
Fixed-In
6.0(1.2120.1)
7.0(0.39000.6)
5.1(3.1111.1)
Symptom:
Conditions:
Workaround:
1st Found-In
6.1
5.0
5.1
6.0
Fixed-In
6.1(0.9901.430)
5.1(3.9901.22)
6.1(1.1000.11)
Hope this helps!
Rob
