Adding Phones in CCME failure
Jan 21st, 2008
The platform is a 2801 router running
OS Description Cisco Internetwork Operating System
Cisco IOS (tm) C2801
Cisco IOS Software C2801-SPSERVICESK9-M
Software Version 12.4(15)T1 / CME 4.1(0)
GUI Version (Compatible with IOS 12.4(11)XJ)
In the GUI when I attempt to add a phone, I can find the MAC of the phone and go through the motions to add it, click save and I get an Error on page at the bottom of the IE browser.
Line: 7153
Char: 13
Error: 'value' is null ornot an object
Code: 0
What is the cause of this? Is it the GUI installed with this version?
rob.huffman Mon, 01/21/2008 - 11:08
Hi Todd,
You may be hitting this bug;
CSCsb35504: GUI interface can't add phone if "no auto-reg-ephone" is set under telephony-service
There is a nice explanation of the problem from NetPro Jorge @ AT&T - Alestra
Hope this helps!
tahequivoice Mon, 01/21/2008 - 11:33
I wish it was that simple, but nope. There are errors on the page itself, the ephone_admin.html page comes up with errors.
If I click on add a phone I get the two phones that are registered in the drop down box, go through the motions of setting the fields, add a PIN and user, click add, get the popup to save and then nothing, but on the main screen there is the error icon in the left corner. I think something got fragged during install. Going to wipe the flash and start over using for the GUI instead.
Paolo Bevilacqua Mon, 01/21/2008 - 12:46
You can try, but have to tell you in honesty, there are many things that the gui doesn't do or does poorly. So rather than trying to fix the unfixable, one uses the CLI and end of history.
whilenski Thu, 07/17/2008 - 10:05
I'm experiencing this with 12.4(15)T5 and GUI (Compatible with IOS 12.4(15)T). I was able to add a lot of phones before when I was first setting the system up, but I'm now coming across this same error.
Any fixes for it yet?
