PagP Priority
Jan 21st, 2008
Hi!
I want to create an Etherchannel with two ports, but I would like than one port carry more traffic than the other. Is this possible? I've seen there is a "priority" command in the pagp configuration to assign port priority, but I am not sure if this works like I would like to...
Thanks in advance!
Best regards
Overall Rating: 3 (1 ratings)
Jon Marshall Mon, 01/21/2008 - 11:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You can't really control the load-balancing as such. You can configure which type of load balancing it will do ie. src/dst mac address, source/dst IP address, port numbers but not all switches support all types.
The Pagp priority command does not affect which link is used for load-balancing.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
Jon
juan-castillo Mon, 01/21/2008 - 11:17
OK! Thank you very much. I supouse I need to use a router to control the load.
Best regards!
