BVI Interface on voice gateway
Answered Question
Jan 21st, 2008
I have a 2801 with a PRI and 2 Fast Ethernet interfaces. We want to dual-home the gateway to separate core switches, with one Fast Ethernet interface to each switch.
My question is what is the best way to do this? I was thinking of putting both interfaces into a BVI interface, but is that ok to use for voice? Or would it be better to use a /30 on each interface, and then use the loopback IP as the routed IP?
Correct Answer by paolo bevilacqua about 9 years 4 months ago
The BVI works fine with voice. And the routed approach also. If you have a voice vlan to be connected directly to the router, the first solution is probably easier.
Overall Rating: 4 (2 ratings)
Correct Answer
paolo bevilacqua Mon, 01/21/2008 - 13:57
  • Hall of Fame,
    Founding Member
degg Mon, 01/21/2008 - 14:07
The gateway is only for the Voice VLAN, so we'll likely be using the BVI interface. Thanks for the input!
paolo bevilacqua Tue, 01/22/2008 - 03:03
  • Hall of Fame,
    Founding Member
Thanks for the nice rating and good luck!
