CallManager 5.1(3) SIP trunk to Broadvoice/Vonage/VOIP provider
Jan 21st, 2008
Had anyone setup a SIP trunk with Cisco Call Manager and broadvoice?
Is there a voip provider that you would recommend that allows SIP trunks to our version of call manager?
shaunewing Sun, 12/28/2008 - 21:31
You will need to find a provider that allows authentication based on IP address, not based on a username/password combination.
What I've done is put an Asterisk box in between CUCM and the providers (Asterisk handles authentication) - it's the easiest way to solve the issue while maintaining flexibility in being able to choose the provider.
