RME - Exemption thrown when retrieving config
Jan 21st, 2008
I get the following exemption thrown when trying to open a config in config editor (RME 4.0.6)
"Exception thrown from TreeGenerator class com.cisco.nm.rmeng.config.cfgedit.ui.helper.CfgEditVersionTreeGenerator Exception is java.lang.NullPointerException"
In my tomcat log (root\MDC\tomcat\logs\stdout.log)
I show:
DEBUG:appID for context:/rme from CCR:rme
Ajp13Processor[9009][8] process: IOException Connection reset by peer: socket write error
any idea's?
Joe Clarke Mon, 01/21/2008 - 15:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is not enough information. You need to post the entire stdout.log as well as the CfgEdit.log.
Joe Clarke Mon, 01/21/2008 - 17:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I do see a lot of errors indicating your config archive on disk may be damaged (i.e. missing revisions that are referenced in the database). However, as to this specific NullPointerException, there is not enough information in the log to figure out exactly why the problem is occurring. You should open a TAC services request so that additional debugging can be performed.
My guess is that this could have something to do with the either the damaged archive or an incomplete RME 4.0.6 update. The archive could be repaired by reinitializing the rmeng database along with deleting NMSROOT\files\rme\dcma\*. An incomplete update could only be repaired by uninstalling, then reinstalling and repatching RME.
