Cisco 2509
Jan 21st, 2008
my setting is as below:
but it would not let me to connect any other device using reverse telnet
as-2509#sho run
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname as-2509
enable secret 5 <<masked by moderator>>
enable password <<masked by moderator>>
ip subnet-zero
no ip routing
ip host r1 2001 172.16.1.1
interface Loopback0
ip address 172.16.1.1 255.255.255.255
no ip directed-broadcast
interface Ethernet0
bandwidth 10000
ip address 192.168.0.30 255.255.255.0
no ip route-cache
no ip mroute-cache
interface Serial0
no ip address
no ip route-cache
no ip mroute-cache
shutdown
no fair-queue
interface Serial1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
ip classless
line con 0
password cisco
login
transport input none
line 1 8
session-timeout 20
no exec
transport input all
line aux 0
line vty 0 4
login
end
Richard Burts Mon, 01/21/2008 - 18:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I wonder why you have configured no ip routing for this router. But I am not sure that this is the problem.
Could you post the output of show line from this router? What kind of connection do you have for the async? Are you sure that the connection from the other device to this terminal server is using the correct cable?
Rick
