CSM 3.1.1 Device provisioning failed null for ASA5520 V7.2.2
Jan 22nd, 2008
Hi, with CSM Version 3.1.1 when i start
Discover VPN policies :
Topology : Hub and spoke
IPsec technology : regular VPN IPsec
Discover from Network
When the system discover my hub ASA5520, i have this message " Device provisioning failed null
Please contact Cisco Technical Assistance"
see the asa configuration :
jsivulka Mon, 01/28/2008 - 07:08
  • Bronze, 100 points or more
A missing comUser.dat is critical as this file contains the trust_user (aka System Identity User) credentials. This file missing can cause components that lookup trust_user information to fail. Provisioning is one such component. With CS 3.1.1, creating System Identity User in CS GUI will create a comUser.dat. But with the older versions, you might get error while trying to edit the System Identity. So it's better to use a backed up comUser.dat.
