Is it possible to connect two routers with VIC-2E&M ?
Jan 22nd, 2008
I have a router 3745 and a 3845.
With the 3745 I have four VIC-2E/M.
So I want to receive calls from these VIC ports.
So what can I do in the 3845? Would I install 4 VIC-2E/M and configure them?
I have not access in the 3745.
Many thanks
Overall Rating: 4 (1 ratings)
paolo bevilacqua Tue, 01/22/2008 - 02:57
  • Hall of Fame,
    Founding Member
Yes, actually the card for the 3845 is vic2-2e/m, plus you need a minimum of pvdm2-8 to activate all 8 channels.
However, considering that the people that administer the 3745 will need to configure something to make the connection, why don't you ask them to send the call via VoIP. It will be much easier and requires no hardware.
connect101 Tue, 01/22/2008 - 03:54
Yes that i've ask them.
But when i said them to configure their router, to be a voip gateway with the command "voice service voip". They said that their router don't support the command.
I wanna do a hairpin call : Call Router C from router A, through Router B.
So if I haven't these option, I have to use the E/M cards.
Thks
paolo bevilacqua Tue, 01/22/2008 - 04:08
  • Hall of Fame,
    Founding Member
In fact voice service voip is not required to dovoip, older IOS may not have the command.
If the 3745 router "sees" the E&M card, it has a voice image and can do voip.
But, router B would need to do IP-to-IP gateway when to using the physical cards.
Do you have IP connectivity between A and C? In that case B would be required at all.
The E/M cards, beside the cost, can be hard to configure and would require a lot of collaboration from router B side.
